Overclocking Guide / Benchmark
Go to solution Solved by DrM,
For cpu, keep voltage under 1.35V and temps under 80C continuous. For gpu, raise core clock as high as it can go, by ~10MHz each time, then OC mem clock if you want (its not as important, might riase frames by 1 or 2 but nothing huge). Not sure about ram. Afterburner is the goto program for oc. For gpu stress teesting, i use furmark and unigin valley, though theres also heaven. for cpu stress test, aida 64. Finally, GPUz and CPUz to make sure the OC worked, and firestrike to benchmark your gpu OC
Hey !  I want to overclock for the first time and i want to know some basic think.  CPU i5-6600k / Gigabyte gtx970 G1
Voltage for CPU ?
Temp CPU ?
tips for GPU oc ?
OC ram for gaming rig ?
MSI burner is good for asus mobo ?
What not to do ? :P
What benchmark software do you use and where i can find it ?
i want to benchmark my CPU and graphique card befor and after OC.
I want to test the stability too.
Any other tips ?
Thank's for your help
https://linustechtips.com/topic/565156-overclocking-guide-benchmark/
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
