idle temps
Go to solution Solved by shadowbyte,
that's fine
anything under 90 degrees is considered a good temparature
Is it okay that i have turned down my fans so when idle, the fans dont kick in before the pc is under load.
That means that i have idle temps at 40*c sometimes its 50*c but drops down after some time.
Under load my max temps are 70*c. and when playing games its only around 55*c
I have a All in one liquid cooler single-rad with 2 noctua fans at push-pull. My cpu :  i5-4690k
i5-13600kf, 16gb Corsair 3600mhz, Asrock z690 ac itx,  RTX 3080 , 1TB+1TB PREDATOR + Western digital NVME, InWin A1, Thermalright peerless assasin 120SE
https://linustechtips.com/topic/564908-idle-temps/
thats perfectly fine.
CPU: me | Dark Rock Pro 3 | Asus Z170-A | 32GB Dominator Plats | 512gb SSD/4TB WD Black | 980Ti | BQ Silent Base 800 | EVGA 850w |
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
BEST PC FOR THE PRICE:
$400 $500 $600 $700 $800 $900 $1000
If you want to Silence your PC/Room more, contact me.
https://linustechtips.com/topic/564908-idle-temps/#findComment-7425934
that's fine
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/564908-idle-temps/#findComment-7425940
