 The situation has been getting slowly worse and now it is unbearable, I now get low memory crashes on the daily, when playing games such as rocket league and CSGO, and after a while even chrome is closed for too much memory use. Also, if I try to play more intensive games like the witcher I get a blue screen saying "SYSTEM_SERVICE_EXCEPTION (win32kbase.sys). I have tried a fresh install of windows and have run many memory tests including memtest which has come up with no errors as well as using a different set of ram which made no difference. I don't know what the issue is but I think it might be the motherboard.
Please help!!
https://linustechtips.com/topic/564686-low-on-memory-crashes-and-more/
How much RAM do you have?
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
Can you open task manager and see how much of the memory is being reported as in use when gaming (this screen in Windows 88/8.1/10, in Windows 7 it's the "resources" tab IIRC)?
memLoad32GBReadable.png.7d270320336e379b
Thats not a memory issue i think, when i overclock and its unstable it crashes with that same message. Maybe you overclocked too much? maybe its a power delivery issue? Hard drive/SSD issue?
Hope this helps :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
This was while playing rocket league, I tried mortal kombat X but it crashed instantly.
Hope this helps :P
I have never overclocked any of the components, and haw could I test to see if it's power or storage device issues?
try running a system stress test, like aida64. and if the blue screen occurs then its a power issue.
Hope you get the problem fixed soon :P
I have run Firestrike, intel burn test and a full system stress test before and it didn't crash
It could be a operating system issue or program issue thats causing it then. It does say  SYSTEM_SERVICE_EXCEPTION so i'm assuming its a software issue. How old is your operating system? if you upgraded from another windows that may have done some crap.
Hope this helps :P
Hope this helps :P
5
It was a windows 8 which was then upgraded to win 10, I built my computer about a year and a half ago, which was when I got the copy of windows.
Try going to settings, Update and security, Recovery then click reset this PC. And follow what it wants you to do :P
I've already tried doing a fresh install using that method and it made no difference.
Does the error only happen with some games? or some programs? or randomly?
No, it happens with all games other than super unintensive ones like titan souls or super meat boy, and programs like dashlane, skype, chrome and Displayfusion all eventually need to be closed due to the issue.
Have you tried furmark? and stress your graphics card?
Yes, I have run 3D mark a lot.
No, try furmark. It will stress your gpu to the upper limit to see if its actually a power issue. Because 3D mark isn't really intensive.
4 minutes ago, llAlexanderll said:
I'll give it a shot now
I tried it and my system held up fine.
I'm not to sure, maybe give it more volts!
Given that you have a second memory kit - have you tried simply running more RAM to see if it stops the problem?
