I am trying to build a PC for myself and its my very first build. Previously I have had a sucky computer and an alienware 14Mx. I just want you help in validating my build and also providing me with any cost saving tips because my current build with the necessary tools included is slightly over budget. If this is an optimal build for gaming and 3d modelling that will sustain for 3-4 years then I can expand my budget to buy these components.
This is my build put in a wishlist at newegg
Beast
This is the build on pcpartpicker with the minimum reqd peripherals
http://pcpartpicker.com/user/Agyey/saved/fRswrH
If it's inconvenient for you to click on the link and go to the newegg website then I will list the components below.
<space for components>
https://linustechtips.com/topic/564164-please-help-me-validate-my-build/
Oh lord, why do you have so much useless crap lie fans a cable ties... And the keyboard sucks too...
Okay. Use this: http://pcpartpicker.com/
Your builds looks pretty god for core components, I didn't bother reading your peripherals and stuff as soon as I saw the zip ties and fans and stuff. You can get those later, don't worry about them now they are highly unnecessary.
Also, I need your budget, location (as in what country you live in), and whether or not your budget includes peripherals or not.
Beast
use pcpartpicker pls.
and whats your maximum budget?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
I originally did but It doesn't list the price of each product in need and also doesn't have certain products. If it's inconvenient then I can type out all the components myself.
I live in India and my budget in usd is 4200 including shipping and peripherals.
whats your max budget? uses? peripherals needed?
i'll build you a better one.
Old Rig
10 minutes ago, Agyey said:
My budget is 4200 USD including shipping and peripherals and I need it for 3D modelling and AAA title games.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($376.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($135.99 @ SuperBiiz)
Motherboard: MSI X99A GAMING 7 ATX LGA2011-3 Motherboard  ($243.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 32GB (4 x 8GB) DDR4-2400 Memory  ($134.99 @ Newegg)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($149.99 @ Newegg)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($119.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 980 Ti 6GB FTW ACX 2.0+ Video Card (2-Way SLI)  ($629.99 @ Amazon)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($139.99 @ Newegg)
Power Supply: Corsair RMx 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($129.99 @ Newegg)
Monitor: Asus PG279Q ROG Swift 165Hz 27.0" Monitor  ($799.99 @ Micro Center)
Keyboard: Corsair STRAFE RGB Wired Gaming Keyboard  ($128.69 @ Amazon)
Mouse: Logitech G502 Wired Optical Mouse  ($69.95 @ Amazon)
Other: NZXT HUE+ ($59.99)
Total: $3732.51
Generated by PCPartPicker 2016-03-12 10:07 EST-0500
Old Rig
Total: $3732.51
Monitor: Asus VG248QE 144Hz 24.0" Monitor instead of Asus PG279Q ROG Swift 165Hz 27.0" Monitor
PSU: Corsair RM 850W 80+ Gold Certified Fully-Modular ATX Power Supply instead of Corsair RMx 1000W 80+ Gold Certified Fully-Modular ATX Power Supply
Case: NZXT Phantom 630 Windowed Edition (Black) ATX Full Tower Case This I can't change.
How about these changes?
Just now, Agyey said:
dude, 2 980Ti's and you want a 1080p monitor? :/
and 850W is cutting it, up to you though. Personally, I'd get the 1000W just to be sure.
Old Rig
The 980ti's are for ads Maya and Max not for display. And the other factor is that I can get 2 1080p monitors instead of 1  4k monitor. I checked the voltages requirements. It says 734W so isn't 850W enough?
If you want 1080p then go ahead, the PG279Q is not 4k. It is a 1440p monitor. I'd rather go 1440p than 1080p for more screen space.
That's not accurate. It is more than that depending on the load of the system, it may go over 850W. If you want unexpected shutdowns due to not enough power then go ahead.
Old Rig
I would change the power supply then. Thanks for you input.
no problem, glad I could help :)
Old Rig
