Hello everyone of Linus Tech! I built my rig in mid 2015 and has the following components;
Raidmax Vortex ATX 420-wb case
MSI H81M-P33 mini-ATX motherboard
Intel Core i7 4790S CPU (liquid cooled with corsair h50)
MSI GTX 960 2gb
1TB HHD
corsair CX600M power supply
8gb ddr3 1600 RAM
*Audio Periferals*
Logitech external speakers
Turtle Beach Earforce x11 headset
okay so Ill make the story short- I had ordered some fans that I needed to install for exhaust (trying out a push/pull orientation). So I popped off the front panel of my case and installed everything A-Okay. Once I booted my computer back up, all of the audio had stopped working. I immediately went to Google and Reddit and read up on some potential problems - my drivers could be messed up... so I uninstalled any existing drivers for my speakers and headphones. Then I threw my motherboard driver disk into my computer and tried reinstalling any RealtechHD audio drivers. no good. My immediate thought after this did not work was that it is a hardware issue. I triple checked my JAUD1 port (the port where I plug in the HDaudio cable that runs from the top of my case down to the lower end of the motherboard. When I looked at the top end (where the chord connects to my case) it had seems as though the prongs were bend downward a little bit. I'm only 20% sure that this could be the problem- HOWEVER I don't think that my computer would recognize audio devices if it were this hardware issue.
I have checked my speakers and headphones and everything is fine with those... they were working as of earlier yesterday and now I get zero audio.
***UPDATE***
--> The VU meter next to my speaker fluctuates with sound... meaning that it is detecting sound... but physically there is still no actual sound
SOMEONE HELP ME! :D
thank you and all the best, Linus Crew!
Curtisbarnesgk
https://linustechtips.com/topic/564146-help-audio-not-working/
Did you try plugging speakers directly to the MoBo I/O (back of the case)
Athlon X2 for only 27.31$   Best part lists at different price points   Windows 1.01 running natively on an Eee PC
My rig:
Celeronator (new main rig)
CPU: Intel Celeron (duh) N2840 2.16GHz Dual Core
RAM: 4GB DDR3 1333MHz
HDD: Seagate 500GB
GPU: Intel HD Graphics 3000 Series
Frankenhertz (ex main rig)
CPU: Intel Atom N2600 1.6GHz Dual Core
RAM: 1GB DDR3-800
HDD: HGST 320GB
GPU: Intel Graphics Media Accelerator (GMA) 3600
https://linustechtips.com/topic/564146-help-audio-not-working/#findComment-7418313
1 minute ago, Bergensaren said:
Quick question, is it front audioo ports or rear audio port you are normally using?
rear audio ports for speakers and front audio ports for headphones - when I plug into both sides windows will recognize that I plugged something in but no sound.
https://linustechtips.com/topic/564146-help-audio-not-working/#findComment-7418331
My rig:
HDD: Seagate 500GB
RAM: 1GB DDR3-800
HDD: HGST 320GB
https://linustechtips.com/topic/564146-help-audio-not-working/#findComment-7418381
8 minutes ago, Djole123 said:
do you think it could be the case audio? in other words, do you think a new case would help the problem?
https://linustechtips.com/topic/564146-help-audio-not-working/#findComment-7418425
Don't think so...
My rig:
HDD: Seagate 500GB
RAM: 1GB DDR3-800
HDD: HGST 320GB
https://linustechtips.com/topic/564146-help-audio-not-working/#findComment-7418443
