so I am running a lan party for a project at school.
It will be run at school where we have 200 up 200 down
what is the best way of networking it (we will likely have about 50 people)
I would also like to run a game server. what is the best way of going about that?
My rig: r7 1700 @ 3.9/1.35v, 16gb ddr4 3200, assorted rando SSDs, hx 1050, vega 64 1650/1025
MY $75 BUILD https://linustechtips.com/main/topic/576889-the-75-build-log/#comment-7547280
https://linustechtips.com/topic/563913-running-a-lan-party/
Hi.
Use ethernet (for those machines that have ethernet) for that. You will probably need an ethernet switch. Talk to your school about getting one of those.
Running game servers can be difficult. I recommend using a different machine to the one you will be gaming on and use it to host the servers. Create LAN servers so others can't join, just those on the network. For the games you'll be playing, just google 'how to host a (insert game here) server'.
Good luck, I wish I could do a project like this for my school!
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415764
Just now, AlphaGamer46 said:
Hi.
yeah man planned on using ethernet. I plan on buying a pc to use as the server. what sort of power will I need?
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415771
Power?
Sorry, I don't understand what you mean by 'power'.
If I am correct and please correct me if I am not, you're talking about the power for the machines.
Technically, you should evenly distribute the power but in my setup I don't. It may be worth using anywhere from 4-10 power sockets with numerous power boards. There shouldn't be a power delivery issue as with my setup, I've got 22 power sockets being powered off of 1 socket on the wall. As long as all of the power cords are firmly plugged in, you should be fine.
2017 Gaming PC
Dell XPS 15 9560
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415790
Power?
processing power for the server. like will 4gb ram and a dual core zeon do?
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415793
Just now, DarkRuskov said:
what games will you be playing to need a server?
counter strike lan, factorio lan, things like that
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415801
Seriously, you don't even need a Xeon for any of that.
Just look on eBay for an old LGA775 build with 4GB RAM and a decent hard drive. That's all you'll need.
It's not like you'll be hosting files or rendering video, so you just need something with speedy ethernet.
EDIT: You would actually be fine with something like a Core 2 Duo CPU, just something that is 'good enough' to stay on for a long time and host gaming servers.
2017 Gaming PC
Dell XPS 15 9560
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415808
counter strike you probably do not need to buy a server, plus setting a server for games yourself is quite time consuming
as it is a project it is something I want to do...
https://linustechtips.com/topic/563913-running-a-lan-party/#findComment-7415814
