So, I use a Hyper 212 Evo, and Fan Xpert to set up fan curves etc. I recently did a fan speed test on the CPU fan, and it shoes that the fan runs at 991-995rpm regardless of power (see screenshot). What the heck is going on here? It used to do fine, but now it seems locked at ~1000rpm. This isn't super important, as my new x79 motherboard is coming in a few days, so fan control will be done by that board, but I'd still like to fix this.
Capture.JPG.e5d36eee92ce344cb8f6bcffd995
Laptop: Asus GA502DU
RAM: 16GB DDR4 | CPU: Ryzen 3750H | GPU: GTX 1660ti
https://linustechtips.com/topic/563884-fan-speed-issue/
2 minutes ago, Rangaman42 said:
well try toggling between pwm and dc at the qfan in the UEFI/bios
my motherboard cant control the fan if its at DC but can control when its set to pwm
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/563884-fan-speed-issue/#findComment-7415477
I'll give it a shot, since HWMonitor doesn't list any PWN fans.
https://linustechtips.com/topic/563884-fan-speed-issue/#findComment-7415486
ah wait, i said it backwards, mine works on DC, not PWM :S sry its 9am and i havent slept
https://linustechtips.com/topic/563884-fan-speed-issue/#findComment-7415521
Hmm I don't have a PWM/DC option. Its still stuck at %1000 rpm :/ should I disable the in BIOS fan control and just try to use AI Suite?
https://linustechtips.com/topic/563884-fan-speed-issue/#findComment-7415909
try to play around i guess
https://linustechtips.com/topic/563884-fan-speed-issue/#findComment-7415912
