Ok so i don't know to much about watercooling. I am looking for a loop for this build: http://pcpartpicker.com/p/shnWVn
and need some help picking the parts for it. I am looking for a full loop with as many radiators as I can get for as little as I can get (but i can figure out money later), while it still looks nice. (don't want a poo brown loop)
I also have a question: Does it make a difference if you run the res>pump>gpu>cpu>radiators>res for CPU temps significantly? or should you go res>pump>cpu>gpu>radiators>res?
Breaking things 1 day at a time
https://linustechtips.com/topic/563707-help-making-loop/
Found this on overclock.net
Hopefully it helps you out :)
http://www.overclock.net/t/913181/water-cooling-guide-for-noobs-always-updated
I've read it, it seems very in-depth and you should like it
GTX 1070 - Ryzen 5 3600x - Corsair H100i V2 - 32GB DDR4 3200
Check out my Minecraft channel here!
https://linustechtips.com/topic/563707-help-making-loop/#findComment-7413330
Ok thanks ill check it out
https://linustechtips.com/topic/563707-help-making-loop/#findComment-7413333
Just a tip from me, use Arctic MX-4 if you want to use a water loop.
https://linustechtips.com/topic/563707-help-making-loop/#findComment-7413345
Just now, TubsAlwaysWIns said:
OK thats probably what I would do since water is cheap
:P Sounds good. I'll head off then. Good luck with your endeavors
https://linustechtips.com/topic/563707-help-making-loop/#findComment-7413356
Loop order doesn't matter as long as your res is above and just before the pump to ensure it doesn't run dry, for GPU blocks and things EKWB is your best bet, their cooling configurator can help you find the block that is needed:
https://www.ekwb.com/configurator/
https://linustechtips.com/topic/563707-help-making-loop/#findComment-7413448
Ok thanks. Ill post links to things on here in a bit so you can approve
https://linustechtips.com/topic/563707-help-making-loop/#findComment-7413459
