Wassup everybody.. so this is my build log for Project MicroWorks...
Here are the Specs:
CPU: Intel 6700K LGA1151 4.0GHz
Mobo: Asus Maximus VIII/8 Gene
RAM: Corsair Dominator Platinum 16GB [4x4GB] @2800Mhz
SSD: Samsung NMVe 256GB 950 Pro m.2
PSU: Corsair RM1000i PSU w/ stock cables
GPU: EVGA 980ti K|ngP|n 6GB of VRAM
CPU Cooler: H100i v2
Case: Corsair Air 240
SoundCard: Asus Strix Raid DLX w/ Asus Strix 7.1 Headset
Capture Card: Elgato HD60 Pro
https://linustechtips.com/topic/563273-project-microworks/
8 minutes ago, Roam027 said:
i need help... my PC is not posting right now... all its doing is B2 error code..
Do you have XMP enabled?
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408155
3 minutes ago, Roam027 said:
its not even posting i tried everything thats possible and i have no video coming out...
Did you connect the cable from the motherboard to the monitor or the 980 ti to the monitor?
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408208
Looks like an awesome build :) hope the post errors solve soon, would love to see this finished
MSI GE72 Apache Pro-242 - (5700HQ : 970M : 16gb RAM : 17.3" : Win10 : 1TB HDD : Razer Anansi : Some mouse) - hooked up to a 34UM58-P (WFHD) in dual screen
iPad Air 2 (for school)
iPhone 6
Xbox One Forza 6 Limited Edition Blue
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408219
2 minutes ago, Roam027 said:
i don't have the 980ti yet.. i am using the iGPU
Try using 2 of the 4 ram sticks.
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408230
thanks.. just waiting on some stuff and all my EKWB stuff and then i need to figure out how to make cables lol.. so i  can get rid of the old one and replace it with short ones so i can have space in the back for drain port and combo unit..
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408233
i tried the RAM.. in every config possible... nothing... same code on every stick... umm i tried unplugging all cables and only leaving CPU power and 24 pin with CPU fan Plugged in for H100i and even took out my 950 Pro... and booted it from the Start button on mobo and still a black screen also i have no prephrials installed or connected either and still nothing
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408243
I looked at the specs of the 6700K, it only supports DDR4 speeds of 1866/2133. You've 2800. :/
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408248
4 minutes ago, Roam027 said:
Manual shows that it supports my 2800 DDR4
https://linustechtips.com/topic/563273-project-microworks/#findComment-7408280
 http://www.intel.com/content/www/us/en/gaming/extreme-memory-profile-xmp.html
@Roam027,
Could you put the pics in one or more spoilers (the eye button on the edit tool bar) please.
Have you tried removing any expansion cards, including any gpu, then booting using the igpu for display?
https://linustechtips.com/topic/563273-project-microworks/#findComment-7409608
