Java Help Please
Solved by jslowik,
Additionally you're never printing the value from that method. Your print line should be similar to:
System.out.println(SecondClassObject.simpleMessage(name));
And just for giggles, writing your second class like the following is a few less keystrokes:
public String simpleMessage(String name){ //this is taking the varible sent from the call method name += " Is a god"; return name; }
