I am looking for the best silent case out there!  I currently have the Corsair Air 540 but it basically wakes the dead when I start it up so I need something a little quieter.  I know NZXT and Fractal Design make really good silent cases but which one is really the best?  Something mATX based would be nice cause that's my mobo but not required, good cooling and fan filters are almost essential.  A side window would be cool but not absolutely needed.  If any of you have ideas on what I should get that would be greatly appreciated!
Current rig if it matters (upgraded it from a prebuilt from Microcenter): http://pcpartpicker.com/p/CMXC3C
i5 12600k | ASRock Z690M-ITX 32GB Corsair Vengeance LPX DDR4 3200MHz | EVGA 2080 Super Black | Samsung 970 EVO Plus 500GB + 980 1TB | Corsair RMx 650W | Thermaltake Tower 100 White
https://linustechtips.com/topic/563221-best-silent-case/
Nanoxia's Deep Silence 6 is a great option
it's stupidly expensive though
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407376
I would try getting some low-noice fans or setting the fan-curves less aggressive. The Air 540 isnt know for beeing loud.
Maybe one of ur fans is broken?
Wheres the noice coming from?
Budget Rig "Curable":     | FX 6300 @4.5Ghz | Asus R9 270x | Asus Crosshair IV Extreme | 16GB HyperX Beast | 120GB PNY SSD
Tablet "Buddy":                 Trekstor Wintron 10.1|
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407382
While cases do help a lot with noise isolation, you should be looking towards suppressing the noise source (unless you are wildly exaggerating with the 'wakes up the dead' analogy).
 Try with different fans, controlling them, changing your cooler, using rubber aid for fans and hdds, etc.
Anyway, from the mainstream cases out there, I'd suggest Fractal define stuff over the H440 (better ventilation). Cooler Master Silencio cases aren't bad, but they are usually overpriced, however often found on sale.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407406
Just put some Noctuas or Noiseblocker fans in there. Done
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407412
I have tried making a fan curve in the BIOS and regular programs but it is just not working.  The noise is just the fans running at what seems 100% all the time.
Yeah way too expensive.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407413
What mobo is it? not all headers on all motherboards have proper fan control.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407428
I linked to all the parts in the original post.  It is just some MSI mobo that came with the prebuilt system I originally had.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407432
Buying a new case then is stupid. What fans are you owning? At what RPM's are these running? (Hardwaremonitor)
Consider buying some high quality fans, instead of a new case. It'll run as silent as my girlfriend locked in my basement afterwards.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407452
I just have the 3 stock fans that come with the Corsair case, the High Performance Air Series AF140L.  I don't know what RPM they are running.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407474
Checked out the motherboard specs, and it seems there isn't really much fan control going on besides very basic control on the main (CPU) header.
You can get a fan controller and start from there.
The NZXT Grid+ V2 is a pretty solid choice, it has immense control capabilities from the CAM Software and costs $30 https://store.nzxt.com/products/grid-v2
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407485
Download the tool "Hardwaremonitor" or smth and look it up. Maybe take a look at the Bios. Are the fans plugged into the Motherboard?
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407490
Wow I didn't even know that existed, thank man.
The exhaust and one intake are plugged into the mobo, only one is into the power supply but could one fan be making all that noise?
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407510
Well, try it out. Block the Fans movement by stopping it by Hand and Listen if its gets much quieter
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7407808
Should I really do that? That seems like it would break or damage the fan...
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7408263
Just dont put any hard materials into the blades. Stopping the motor for a moment wont do anything.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7412826
I actually stopped all three case fans and it got quiet quickly even though two of the three are controlled by the mobo.
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7419307
Get a fan hub/controller/voltage regulator for ur noisy fans or get silent ones. These are ur problem, not ur case ^.^
https://linustechtips.com/topic/563221-best-silent-case/#findComment-7419320
