Is this fan better than the stock 212 evo fan?
GeorgeKellow
Sp120s are nice. The Hyper 212 Evo fan isn't bad though. If you are happy with the noise already then you won't really get much quieter.
Buy a single NB eloop, unless you are going for a red theme, then yes it is better than the stock fan
Fuck, I linked the wrong one, its the af version
Get the SP, it is designed for rads and heatsinks
I've got the af one. will it be better than the stock 212 evo fan>
reglardless of which spec the fan is, you still wont lose much noise to where it would be noticeable
unless you need a single fan for something else and you have a second as a bonus, in which case yeah the sp120 would better
what I'm saying is if you're going to spend $20 or whatever on new fans just for the hyper 212 just save your money and get a NHD15 later.
I've already got this fan as an exhust. My plan is to use that corsair fan as my heatsink fan then use the ltt 140mm and the back as an exhust
heat sinks really just need air flow over them, I suppose if you have both I'd put the airflow one in the rear of the case and keep the stock one on the 212.
if we're talking performance wise they will likely be the same on the heatsink, and noise wise you're running both anyway so it won't matter.
yeah, though it wont make that much difference on temperatures
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
