Hi.
I bought a composite to VGA converter box only to find out I had actually bought the wrong one.
It is VGA to video with a composite out over composite in.
Is there a way to use the composite out as a composite in port?
Thanks, Alpha.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
https://linustechtips.com/topic/561634-using-composite-out-as-composite-in/
6 minutes ago, AlphaGamer46 said:
Hi.
Thanks, Alpha.
It depends how they wire it, if they are just a straight pass through or adapter like theses cable it might work. I would give it a go and see if it works or not.
It is a box like this, minus the LED light.
Thanks again, these boxes aren't cheap so I would love to get it working! -Alpha.
2017 Gaming PC
Dell XPS 15 9560
The cable version in the photo can operate in either direction since it's just physically changing the format of the connector, but if it's an active adapter that does processing or power in from what that one in the image looks like it may not work on both directions. As said though it wouldn't hurt giving it a try but I don't think they will function backwards unless it's just a different format of the cable type ones.
I tried it when I first got it but to my dismay, it didn't work.
I will work something out. Thanks for your help, Alpha.
2017 Gaming PC
Dell XPS 15 9560
