depends on the game which game is that
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757156
Im using MSI After Burner and Riva Tuner in game to check my gpu usage and im only using max 50-55%. Is this a bottleneck of some sort? I have a Phenom X4 965 @4.0 Ghz
the cpu will bottleneck the card in bf3 but not that much lol. temps on cpu ? screen res ?
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757181
Battle Field 3
might be cpu bottleneck because i see %80-%90 usage with 1080p anything besides aa is maxed ,but its ok as longest you get good frames
http://i.imgur.com/JiMt2Ht.jpg
(3570k 4.2)
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757183
BF3 Online is very CPU taxing. You will not get great performance with your CPU when playing BF3 online with a full map. I run the game on Low setting with 4X MSAA just to help keep the frame rate from going into a slide show during times when tons of stuff is happening on screen in BF3 online.
AMD Phenom II x4 955 OCed, HD 7850, LG 27EA33 1080P IPS, 4GB ram
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757307
Its at around 58 degrees celcius and im at 1080p.
Uhh the maximum safe operating temperature indicated by AMD is 62*C. Getting a little close...
Are you running the game in Windowed Mode for Full Screen? You need to be on Full Screen.
Is your HD 7850 clocking up to it's full 3D speeds?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757352
Woops I gave you the GPU temp instead. The cpu is at 50 degrees in game full screen
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757372
Im playing on low settings two but with texture turned uo a little bit.
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-757485
What's your framerate like?
To verify that it's a CPU bottleneck why don't you turn your graphics settings to max including AA and see what happens to the GPU usage then.
What i played at was max all texture 2X af and i got around 60-70 fps and drops of 30
https://linustechtips.com/topic/56104-7850-low-gpu-usage/#findComment-760276
