Erratic Temperature readings
Solved by W-L,
10 minutes ago, zeraine00 said:aida 64 and cpuidd pef monitor
With such high idle temps it's almost always caused by a bad mount. I would suggest to remount to see if they will improve but if they still continue you might want to look into the washer mod, its a fairly common thing on certain motherboards which cause a lack of mounting pressure:
http://www.overclock.net/t/1465656/concerns-about-newly-installed-corsair-h100i
