I don't know if my build could possibly get any cheaper than this (other than if I decide to buy from different merchants.) I really don't have much money, and I'm just looking for a decent build for 900p gaming. Going to run it with Windows 10.
PCPartPicker part list: http://pcpartpicker.com/p/bM6fJx
Price breakdown by merchant: http://pcpartpicker.com/p/bM6fJx/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($122.00 @ Amazon)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($49.99 @ Amazon)
Memory: Crucial Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($31.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($53.99 @ Amazon)
Video Card: Gigabyte Radeon R9 380 4GB SOC Video Card  ($204.99 @ Amazon)
Power Supply: EVGA 500W 80+ Certified ATX Power Supply  ($34.99 @ Amazon)
Total: $497.95
Generated by PCPartPicker 2016-03-06 16:54 EST-0500
Can anybody with an i3-6100 confirm that this will actually run okay? Do I need to put in an extra 60-75 USD for an i5? I'm not planning on really playing anything heavy, but I think if I have a sudden change of heart my graphics card would make up for the lack of CPU performance in some games. I know it's a decent GPU. I'm probably going to end up upgrading a year or less after I buy this PC. I'm going to make the transition from an i3 to an i7, so I can do more with my PC like mess around with video editing, programming, etc... I chose the single 8GB stick because my motherboard only supports two RAM slots, and I might buy the same set of RAM even if I do decide to get a new motherboard.
After I buy a new CPU a few months to a year after the purchase of this thing, which component should I upgrade next? Thanks for any help that is provided.
https://linustechtips.com/topic/560817-skylake-i3-build/
Get a better PSU. That EVGA one is very low tier. If your budget allows it, yes, go for the i5. Games like GTA V and Fallout 4 will benefit with four actual cores.
I'd advise getting a better variant of the R9 380 as Gigabyte models are pretty meh:
Memory: Kingston HyperX Fury Black 8GB (1 x 8GB) DDR4-2133 Memory  ($35.99 @ Amazon)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($189.99 @ Newegg)
Power Supply: XFX XT 500W 80+ Bronze Certified ATX Power Supply  ($56.98 @ Newegg)
Total: $508.94
Generated by PCPartPicker 2016-03-06 17:02 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7378868
Total: $508.94
I'll take the advice for a better variant of the R9 380. However, I'm probably not going to buy an expensive PSU unless the one I chose has a high risk of damaging my system. Taking a look at jonnyguru's review of the PSU and the tons of positive reviews of it on Amazon and Newegg, I think I am fine for now. If need be, I'll go ahead and buy a replacement PSU before I buy my i7.
I'm just on a budget right now... I do strongly believe the PSU will be fine for the time being.
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7378889
Jonnyguru even mentions the meh 12V ripple suppression, it's not suitable to be paired with something like the R9 380 as a gaming build. It also ranks very lowly in quality:
The XFX PSU is a much more reliable option for a few bucks more.
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7378944
I guess, yeah, but he does also say...
Quote
What you do get is quite possibly the most solid forty dollar unit on the market today. Would I buy it myself? If I was on that tight a budget, yes. I would. Again... you could do a heck of a lot worse, and not just at this price point.
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7379568
Well if AM4 launches soon that'd be a decent quad core option potentially if the price is right
That motherboard's IO is crap man, for $15 more you get USB 3.1 and Type C with this board, as well as all the display outputs you could want
https://pcpartpicker.com/part/gigabyte-motherboard-gah110ms2hp
otherwise that's going to be the minimum you'd want
600B is another PSU option
https://pcpartpicker.com/part/evga-power-supply-100b10600kr
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7379701
If you're really, really on a budget, I'd get a 500B or 600B. I don't recommend it but it's better than that 500W White.
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7379785
What is IO? lol
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7379831
2 minutes ago, rose.thashton said:
What is IO? lol
the ports available on the board
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7379850
8 minutes ago, rose.thashton said:
Oh... I only need very basic ports. I don't even use any USB devices other than a mouse and keyboard.
I'm pretty sure it'd be worth it to spend the extra 15 bucks and have future compatibility with a smart phone, or the additional display output options.
https://linustechtips.com/topic/560817-skylake-i3-build/#findComment-7380060
