Overclocking Issues
2 hours ago, Dransk said:Thank you I will try that however, I am not sure how to change the voltage of my CPU on the krait bios settings. Can you please help, it was a lot easier on this gigabyte board I used once
It's pretty simple in that BIOS. See where it says "CPU Core Voltage"? Click on "Auto" and change it to "Override", then enter the voltage you want to use in there. I recommend bumping it to 1.1v, then going in .025v increments from there to get yourself stable. If you're oh-so-close to stability at a given voltage, particularly as you climb north of 1.2v, you can try playing with the VCCIN, system agent and I/O voltages a bit--we'll cross that bridge when you come to it.
Another thing you can do to help early on is to go back up to your CPU multiplier, and in a box below that, you should see "CPU Cache Ratio", or something similar. Setting it to 33 could buy you a little added stability while you test, then bring it up from there.
The "safe" max voltage for Haswell chips is 1.3v, but if your load temperatures are staying well below 80C, you could conceivably push as high as 1.4v at risk of degrading your CPU over time.
