I'm looking to purchase a couple of android phones for use in the lab. They must meet the following requirements:
- Removable battery
- Replacement batteries available for purchase from somewhere
- ~5"
- Android SDK API level 15+ (i.e. Android version 4 or higher)
- Built in sensors (Accelerometer, gyro, magnetometer)
What is the newest android phone that meets those requirements? And as a plus, the larger the battery capacity the better
https://linustechtips.com/topic/559718-android-phone-with-removable-battery/
LG G3
has a removable battery, replacement batteries available, has android version 4 or higher, has an accelerometer, gyroscope, and I'm not sure about the magnometer
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
LG G4 is a pretty good one.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
