I've been looking for awhile now to find a case that I can build my first custom loop in.  I've found that the best cases for a custom loop would be a Phanteks Enthoo Primo or Corsair 900d with my preference leaning towards the Phanteks.  Wanted to see if there was anything else out there that I may have missed. Also before anyone posts it, yes I know a Caselabs is about as good as it gets for custom water cooling, but as this is only my first loop I'm not gonna for for one yet. Additionally its a black and white build and I would prefer a white case but am open to black ones too.
i7 4790K | MSI Z97S Krait | Gigabyte 980ti Gaming G1 SLI |  2x8GB Kingston HyperX Fury | Samsung 850 Pro 1TB + WD Black 4TB | EVGA Supernova P2 1200 | Phanteks Enthoo Primo (White)| Dell P2715Q x2 | Corsiar K70 | Corsair M95 | Full Custom Loop CPU + GPUs
https://linustechtips.com/topic/559716-case-for-custom-loop/
2 minutes ago, GetShrektMrKrabs said:
the Cooler Master  Master Case Pro 5 is suppose to be pretty good for custom loops, while saving you over $100 on from the 900D.
Yea I saw that case but was to small for the loop I was planning on running. Still a really nice case though.
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367550
760d, 760t, caselabs?
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367572
Was going to run a 480 Rad > Reservoir > Pump > CPU > back to rad for now but am planning to put 2 GPU's in it later at that point adding at least another 360. Also despite this being my first loop I am definitely going to hard pipe it so that is something to take into consideration.
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367596
Just now, Hackentosher said:
Caselabs, Phanteks, or a Corsair 760t or 780t. It really just depends on what you want to do and how much radiator space you want.
1 minute ago, GetShrektMrKrabs said:
i have the 760t and was barely able to fit EKWB's  X360 kit in it IMG_2281.thumb.JPG.db699e7285175920a1969
Yeah I remove my vote for Corsair cases, go with a Phanteks or Caselabs.
ASU
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367602
yea was leaning towards Phanteks from the beginning because Caselabs is so expensive.
Don't forgot about the 800D as well.
Not a fan of the 800D styling, especially the top ventilation and side window
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367632
Right, even the sm8 is super expensive. Perhaps a Phanteks Evolv ATX?
ASU
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367638
Just now, GetShrektMrKrabs said:
rule of thumb is 120mm for each component added to the loop, so if it is 2 GPU's and a cpu block then a 360 rad would be enough for it, or even just 2 240's
Are your cards and CPU overclocked? You should add a little more surface area if so.
ASU
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367646
Really like the Evolv ATX but have looked at a lot of pictures of custom loops being super cramped inside of them making maintenance work difficult.
Once the loop is installed I'm going to pin them.
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7367685
Phanteks Enthoo Evolv ATX, the whole right side is empty, with a pump mount built in and plenty of rad support, even has a res mount next to the I/O shield.
 CPU: Intel Core i5 6600K  Motherboard: Asus Z170-A  CPU Cooler: Corsair H110i GT  GPUGigabyte GTX 980 Xtreme  RAM:2x8gb HyperX Fury  SSD: 120gb A-Data  HDD: 1Tb WD Blue 7200RPM - 750gb Hitachi 2.5" HDD  PSU: EVGA SuperNova G1 650W  Case: Phanteks Enthoo Evolv ATX  Monitor: 27" AOC LED IPS x 2  Keyboard: Corsair Strafe RGB Silent  Mouse: Corsair Scimitar RGB
 HeadsetLogitech G430
https://linustechtips.com/topic/559716-case-for-custom-loop/#findComment-7368543
