So i just got my HyperX Cloud II headphones and it seems that the audio is kind of flat and not enough bass this hurts my ears, My friends with the same headphones has the same problem, Any free software/drivers/programs to enhance the audio on my headphones? It needs more bass. My mobo is msi and has Realtek HD Audio but it will not detect USB audio
https://linustechtips.com/topic/559483-hyperx-cloud-ii-sound-flat/
how does it hurt your ears?
having no bass should hurt your ears less
are you talking about the highs being too loud?
the reason it sounds flat is probably because the previous headphones you used had way too much bass and your ears had to adjust to that
What did I just read? How can not enough bass hurt ears? You do know that the little shit usb dongle you get with the cloud II are a sound card and it has nothing to do with your onboard right?
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
Well I'm more used to having bass headphones, When i play csgo with these headphones shooting has a really high sharp sound it gives me goosebumps. I want to be able to feel the punch from the shooting. With these headphones i feel nothing but high pitch noise
52 minutes ago, Digital_ said:
I didn't know the lack of bass could hurt someone's ears...I'm guessing you're more used to bass oriented headphones then? I have a cloud I and it isn't flat at all. If you could explain more about why it hurts that would be great.
This headphones have a high pitch noise and hardly any bass. I wanna feel the punch noise when im shooting in fps not just a flat sound of a gun shooting i want to feel it like my other headphones i can enhanced them, But for the cloud i cant do anything so i'm looking for a program that i can config the sound to my liking
35 minutes ago, SSL said:
If you just got them you can return them. Do so, and get a headphone with more bass.
Most heaphones comes with driver utility so you can config the sound to your liking, but the cloud II doesn't and its prob the best fitting headphones for me so im just seeing if i get help finding a proper software i can config the sound to my liking
Just find a EQ
(the could is a headset and no little to none headphones comes with software, it's really only "gaming" headsets that comes with software.)
