My cat got into a fight outside (and lost) and as a result she nearly spent her 9th life. So my family decided after the hefty vet bill that she'd be an indoor cat now. One of the things she would do outside is scratch her claws on an ironwood tree to keep them down, but she cant do that now. So I was wondering if you cat people would have any suggestions on what would make a good replacement for something to scratch, before she starts tearing up my room.
Pic related, its my cone cat :3
.Her name is bitty
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/
Cat scatcher?
PC SYSTEM: Fractal Design Arc Midi R2 / i5 2500k @ 4.2ghz / CM Hyper 212 EVO / Gigabyte 670 OC SLI / MSI P67A-GD53 B3 / Kingston HyperX Blue 8Gb /
WD 2tb Storage Drive / BenQ GW2750HM - ASUS VE248H - Panasonic TX-P42ST60BCorsair AX750 / Logitech K360 / Razer Naga / Plantronics Gamecom 380 /
Asus Xonar DGX / Samsung 830 256gb / MEDIA eMachine ER1401 running OpenELEC XBMC with Seagate STBV3000200 3TB Hard Drive - Panasonic TX-P42ST60B
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754508
I've had cats all my life. Currently have 3 and giving them a cat tree saved my chairs. They like the feeling on their claws and it gives them something to play on. My cats sleep on the two pillars every night.
This one stands about 5 feet tall
Edit: As I look behind me at the same cat tree.... That is either one freaking huge cat or mine is just larger.
Also digging your 400s.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754521
Cat tree. my cats already destroyed the back if my chair.
My rig  case- Graphite 600t white CPU-i5 3570k OC 4.0Ghz RAM- 8gb Vengeance memory HDD-WD Black 1tb PSU-tx650 GPU- MSI 770 gameing edition 2gb , gtx 650 1gb Motherboard- asrock extreme 3 z77 Fan controller- NZXT sentry lx CPU cooler- H60 Peripherals- g300 mouse G630 headset k70 silver cherry mx red switches  my free nas nas Case- Dell something.. Ram- 8 gb ecc ddr 2 CPU - Pentium D 3.0ghz HDD currently 160 gb adding 3tb wd red “Sucking at something is the first step to being sorta good at something” –Jake the Dog
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754527
Aww adorable, also did you get them for karma? (:
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754530
Just really like cats :)
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754536
Just really like cats :) :)
Btw off topic but for your planned build I think it would look AMAZING in a 350D...
<p>Mobo - Asus P9X79 LE ----------- CPU - I7 4930K @ 4.4GHz ------ COOLER - Custom Loop ---------- GPU - R9 290X Crossfire ---------- Ram - 8GB Corsair Vengence Pro @ 1866 --- SSD - Samsung 840 Pro 128GB ------ PSU - Corsair AX 860i ----- Case - Corsair 900D
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754561
Yeah was curious since you are a redditor, lol (:
I will admit my cats have got me a nice chunk of karma on reddit =D
It's just to plain looking.
I'm going for more of a holy s*** you have that in there!?! kind of build =P
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754573
Point taken..   :o
That's going be an amazing build than!  Good luck man :P
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754577
If she preferred that particular tree you can always try and bring a piece of it inside. Other than that there's the usual scratching trees that should work out just fine, although it may take a while to make her understand that that's the one and only place that can be scratched. Alternatively you can cut her claws, we did this when we had indoor cats and it worked out quite fine. :)
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754606
i just let my cats(three of 'em) scratch my computer chair. they seemed to enjoy climbing around it very much. well the chair is certainly cheaper than a cat scratch post here so that's fine with me. they are not de-claw btw.
https://linustechtips.com/topic/55943-linus-tech-tips-cat-tips/#findComment-754662
