Well i've been building this small beast and planning his creation since August of last year. Day by day buying each part until today where i got my planned beastly AiO cooler by EKWB the predator 240...... but it won't fit... in the corsair air 240.... the pred. 240 was actually a little more bigger than 240, so i have mounted as right now to the top of my case on the outside of the case with the top panel off. I'm kinda at a loss of what i should do. My only options i have in mind is buy a new case to fit all my part but i don't know any specific cases that are micro atx that will definitely fit the pred. 240.  I'm hoping someone here can help me with recommendations on a case or a way to make it fit or something. If you want to look at the build here it is on PcPartPicker.com http://pcpartpicker.com/p/qYTZkL
https://linustechtips.com/topic/558750-my-micro-atx-build/
Corsairs website says that it can fit 240mm radiators in the front and top.  Since the EK rad has the pump on the radiator itself, it won't be fitting in the Air 240.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/558750-my-micro-atx-build/#findComment-7352651
yup, thats what i ran into the hard way today, i didn't rough put it in or anything but i'm just at an impasse and i don't know any solutions from here. Kinda just fishing to see if anyone else has had this kinda exact problem and found a creative way to work around it or i something.
https://linustechtips.com/topic/558750-my-micro-atx-build/#findComment-7352680
Sorry but the air 240 seems like a flawed case to me. Rad support is not the greatest, as the motherboard can easily interfere and air cooling is very limited since height of GPUs used should not exceed reference coolers by much and CPU tower heatsinks are basically a no-go as well.....well decently big ones at least.
Not saying the case doesn't look good, but it doesn't make that much sense to me.
You might be wondering why I am telling you this and...well I would buy a different mATX case. Something like the Evolv or a Fractal Arc mini.
PC: AMD Ryzen 7 7700 || Noctua NH-U12S SE2 || 32GB DDR5 6000 CL32  ||
|| Powercolor RX 9070 Reaper || Asus B650E-I
  || WD 850X 2TB ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
https://linustechtips.com/topic/558750-my-micro-atx-build/#findComment-7352723
4 minutes ago, wonderouspizza said:
would those fit the pred 240?
The fractal arc is THE mATX case for watercooling. I believe it even supports a 360 in the top, never mind a 240. So even if the ek 240 needs more space, that should be accounted for.
The evolv should also be fine, but I can't check that right now. Though I believe it has those rails to mount a radiator in the top, so there is some extra space afaik.
BTW, please quote posts you are answering to. That way people actually get a notification when you react to their posts and are more likely to respond.
https://linustechtips.com/topic/558750-my-micro-atx-build/#findComment-7352806
ohhhhh, thank you! i'm very new to this site and quoting people's messages and stuff. I don't think i'll be going as big as 360 even though it's better cooling but i'm really into the evolv case.
https://linustechtips.com/topic/558750-my-micro-atx-build/#findComment-7352814
Well I only pointed out the 360 fitting to show you that the ek 240 should definitely fit. ;-)
https://linustechtips.com/topic/558750-my-micro-atx-build/#findComment-7353003
