6 minutes ago, jasonvo said:
Hi everyone ! I got one question about the CableMod C-Series AXi, HXi & RM Cable Kit - BLACK / REd. Can this kit fit with 3 or 4 GPUs? Pls help me !!!!!
Thank you all of you guys !
Here’s what you get inside the box:
  • 1 x 24 Pin ATX Cable (600mm)
  • 2 x 4+4 Pin EPS Cable (700mm)
  • 2 x Dual 6+2 Pin PCI-e Cable (750mm)
  • 4 x 6+2 Pin PCI-e Cable (600mm)
  • 1 x Quad SATA Power Cable (850mm)
  • 1 x Quad SATA Power Cable (700mm)
  • 2 x Dual SATA Power Cable (500mm)
  • 1 x Triple 4-Pin Molex Cable (750mm)
  • 2 x Dual 4-Pin Molex Cable (500mm)
  • 1 x Molex to Floppy Adapter (100mm)
https://linustechtips.com/topic/558740-cable-mod/#findComment-7352584
^This.  Yes it will work.  The Dual 6+2 will be enough for 1 GPU each and you'll need 2 of the single 6+2 pins to power the next 1/2 GPU's.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/558740-cable-mod/#findComment-7352604
