So my motherboard in one of my old PCs is an LGA 775 Socket, Fujitsu D3041, and supports;
Which CPU would be best to upgrade to the Q8XXX or the Q9XXX series?
The PC will be used for everyday tasks and gaming, coupled with a R9 270X.
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
https://linustechtips.com/topic/558632-need-help-with-cpu/
9 hours ago, archelocke said:
Can you really not just upgrade your motherboard and get a new CPU? The Core 2 Quads are oddly overpriced and outdated.
I cannot that would be out of my price range and I can get a Core 2 Quad for £15
https://linustechtips.com/topic/558632-need-help-with-cpu/#findComment-7353270
it may support up to the Q9650
those may be higher than the most common Q6600 but they will be the fastest chip
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/558632-need-help-with-cpu/#findComment-7353313
