New PC need help with cooling
Go to solution Solved by Spork829,
1 minute ago, Darkzed1 said:
Ya I am thinking of doing a full custom water-cooling setup but I feel like it would get really messy with the two graphics cards not to mention all the micro management. I might put two 140mm industrial grade intake fans on the front and two exhausts. the issue with adding the extra fan to the front is that it only fits a 200mm fan or two 140mm and so on.
Okay, 2 intake and 2 exhaust should be fine. A custom water cooling setup with the dual cards and everything would indeed get really messy, take quite a bit of know-how and be pretty pricey. More up to you whether you can afford it and if you're confortable setting that up. I'm sure there are guides out there for water cooling a CPU and two graphics cards. Good luck if you do decide to go with the custom setup. Will be awesome if you pull it off.
I am building a new PC and would like to know if I should switch out the case fans, and I am going to be switching out the radiators 140mm fans with another brand any suggestions?
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  ($376.99 @ SuperBiiz)
CPU Cooler: Corsair H110i GTX 104.7 CFM Liquid CPU Cooler  ($119.99 @ Amazon)
Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3 Motherboard  ($308.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($65.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($86.75 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 980 Ti 6GB Superclocked+ ACX 2.0+ Video Card (2-Way SLI)  ($649.99 @ Amazon)
Case: Phanteks Enthoo Luxe ATX Full Tower Case  ($149.99 @ Amazon)
Power Supply: EVGA SuperNOVA 1000G2 1000W 80+ Gold Certified Fully-Modular ATX Power Supply  ($163.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.89 @ OutletPC)
Total: $2642.45
https://linustechtips.com/topic/558584-new-pc-need-help-with-cooling/
Put all Noctua fans in your case and on rad and you would basically hear nothing other than the fans on the GPUs.
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
Fans by NZXT or Noctua are my personal favorite choices, but any big name brands would work. The case fans will work just fine, though from images I can only see a rear exhaust. If it comes with front intake as well you shouldn't really need to add additional fans unless you see bad thermals once you build the thing.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
There is a 200mm fan on the front as an intake, one on the top that I think is an exhaust, and what kind of 140mm fan from Noctua would u recommend for the radiator?
Honestly I've never used liquid cooling and am therefore not someone to ask about fans for a radiator Anything from Noctua will most likely do though, depends on if you want better cooling or quieter operation. 2 exhaust and 1 intake is not a great setup though, as you'll have negative air pressure which will suck dust and grime into the case. I would recommend taking out the fan on top and installing it as a second intake in the front. Will work ok as it is, but will collect more dust faster.
If I ever did do a custom water-cooled setup I would just make a custom case to make it all fit haha. Thanks for the advice I don't mind the PC getting super loud as long as it is cool so I am not terribly picky about sound I have used many loud computers and you just tune it out (unless its jet engine loud) anyways thanks again for the advice I will probably go two intake two exhaust along with the water cooled GPU since that will be getting crazy temps.
Sure thing! If you don't care about silence then get the best fans of the size you want that Noctua has within your price range. Have fun with the build :)
