3 minutes ago, SAT01 said:
http://s304.photobucket.com/user/225sunray/media/Screenshot%2035_zps5flw8hl0.png.html
Please Help!!
Got this on a site to check the weather!
Malwarebytes and Avast came up clean!
It is most likely an issue with Google Chrome fully reinstall chrome first uninstall it and if that doesn't work reinstall windows
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/558462-help/#findComment-7349711
Mom, is that you? It's a website. :D If the programmers choose for it to display a random error message, it'll do that. It doesn't mean you have errors. You can make one too. Write lot's of scary stuff down and save as .html
Or just close the notification and close the tab. Do not call that phone number!
https://linustechtips.com/topic/558462-help/#findComment-7350778
