Just now, Hackentosher said:
WOO S6 BUDDIES!!! *jumping high-five* Honestly, any Qi(is that how you spell it? idk) charger off amazon should do the trick.
http://www.amazon.com/RAVPower-Wireless-Charging-Qi-Enabled-Devices-Black/dp/B00H9B7ALK/?tag=at88-20
what do you think about this one? cheap, has good reviews, etc
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7347143
Just now, ZeusXI said:
Looks good to me. Consider this Aukey http://www.amazon.com/Wireless-Charger-Aukey-Charging-Qi-Enabled/dp/B019WEURSY/ref=sr_1_1?s=wireless&ie=UTF8&qid=1456897625&sr=1-1&keywords=aukey+wireless+charger. I bought one of their quick charge 2.0 chargers and it's pretty great. The connector on the cable starts nice, but it's not durable at all, I just had to throw the cable out a week or two ago because it was flopping around inside the connector housing causing all sorts of issues with locking. Other than that, Aukey is a good brand, and for $10 cheaper, can't hurt, right?
ASU
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7347159
Also, i have an otterbox so i dont know if that would effect the charging in any way. like if i put it on the charger, it wont charge correctly or not.
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7347160
It might, I don't know what the range is on charging but I'd assume it's less than 2cm. Check Otterbox's website and see if they list wireless charging compatibility.
ASU
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7347167
24 minutes ago, ZeusXI said:
Anyone got any ideas on wireless charging pads? im interested in getting one since im always on the go and i dont like connecting and disconnecting my phone
I thought wireless charging was a good idea until I saw how slow it was. Thought about a dock instead?
Main PC CPU: 7700K, MOBO: Asus Strix, GPU: Aorus Extreme 3080, PSU: EVGA Supernova G2 750, RAM: Corsair Vengeance 16GB Storage: 970 Evo 1tb
Lounge PC CPU: 4790K MOBO: Asus Hero VII GPU: EVGA 3060 Ti PSU: Corsair RM650 RAM: Kingston HyperX 16gb Storage: 970 Evo 1TB
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7347225
Check this thread out, my reply there can be applied here as well:
Intel 4770k@4.6GHz, ASUS ROG Maximus VI Hero, Kingston HyperX Beast 2x8GB 2400MHz CL11, Gigabyte GTX 1070 Gaming, Kingston HyperX 3k 240GB - RAID0 (2x120Gb), 2xWD 1TB (Blue and Green), Corsair H100i, Corsair AX860, CoolerMaster HAF X, ASUS STRIX Tactic pro, Logitech G400S, HyperX Cloud II, Logitech X530, Acer Predator X34.
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7348143
too slow? really? lol wired quick charge is like 1 hour 50 minutes. wireless charging is like 2h50 minutes. 1 hour isnt a long time.
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7350762
You don't think an hour extra is long? I'd rather plug it in and charge it quicker than wait an extra hour for wireless...
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7352778
3 hours ago, ZeusXI said:
An hour isnt much. now the older models take like 4 hours to charge
It is when you're on the go often. Are you using a wall outlet to charge your phone? Shouldn't take more than an hour.
https://linustechtips.com/topic/558204-wireless-charging/#findComment-7358650
