Hello. Im updating my AMD FX-6300 and Im buying a cooler called Cooler Master Hyper 212 EVO, but I need a case for that. Since my PC isnt very good, I dont want to spent more than 60, 70 dollars for that. Lot of people suggested me the CORSAIR SPEC-02/03 cases, but the problem is that doing research on Google, people say you cant put CM EVO in that case, but this link https://pcpartpicker.com/parts/case/?compatible_with=cooler-master-cpu-cooler-rr212e20pkr2 and this video
shows diffrently.
SO MY QUESTIONS FOR TODAY IS:
1. Can I put HYPER EVO 212 in Corsair Spec-01/02 cases or
no?
2. What is actually the best case
up to 60, 65$ to put this Cooler and for abilities/design?
https://linustechtips.com/topic/557290-help-with-choosing-case/
shows diffrently.
no?
I don't know about the Corsair cases, but the NZXT S340 does fit it and is $5 over your budget.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/557290-help-with-choosing-case/#findComment-7337947
1. Yes, but the ends of the heatpipes might touch your side panel(which I wouldn't recommend)
2. s340 is beautiful you can get it new for $69.99 or a refurb from NZXT's website for $59.99
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/557290-help-with-choosing-case/#findComment-7337959
It should fit but it would be very close.
For a $70 budget, i too would recommend the s340, i would also tell you too look at the NZXT h320DefineS, Shinobi, Shadow or Ronin.
The ultimate thing to do would be to save enough for a mid/full tower for $80-$100 and you will be sure to get a really nice case that will fit the 212evo.
A water-cooled mid-tier gaming PC.
https://linustechtips.com/topic/557290-help-with-choosing-case/#findComment-7338043
So then NZXT S340 is going to be my choice problaby.
And what would you recommend in 80-100 budget if I may ask?
https://linustechtips.com/topic/557290-help-with-choosing-case/#findComment-7338206
