Any suggestions on how to configure my current components for positive air pressure? I know I am not configured like that now and could use some advice on an optimal setup. Below is my current config.
Case:
be quiet Silent Base 800 (no window; has 1 fan mount on each side panel, both are filtered)
Intake (front - filtered):
2 be quiet Pure Wings 2
Exhaust (unfiltered):
2 Corsair SP120Ls (top; h100i)
1 be quiet Pure Wings 2 (rear exhaust)
PSU Fan (bottom filter):
Corsair AX860i Fan facing down
CPU: Intel Core i7 5930K | CPU Cooler: Corsair H100i | Mobo: MSI X99A SLI PLUS | Memory: Crucial Ballistix Sport 16GB | GPU: MSI GTX 970 4GD5OC
Storage: Samsung 850 EVO 250GB + Western Digital BLACK 2TB | PSU: Corsair AX860i | Case: be quiet! Silent Base 800 | OS: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/557001-positive-air-pressure/
2 minutes ago, keleja said:
-SNIP-
I would suggest to add an extra fan at the bottom as intake or to either keeping the three exhaust fans always close to idle and have the fronts run at a higher speed making it so that the intake volume is higher than exhaust.
https://linustechtips.com/topic/557001-positive-air-pressure/#findComment-7334847
Optional Fan Installation
Top (mm)
2 x 140/120
Bottom (mm)
1 x 140/120
Side panel (mm)
1 x 120
if you install the 2 top once, put the one on the bottom and side panel in as well.
Since the fans on the h100i should not be turned down too much.
I speak my mind, sorry if thats a problem.
https://linustechtips.com/topic/557001-positive-air-pressure/#findComment-7335027
