So i have an old NZXT Phantom 530 that has had the wiring harness' annihilated by rats. Anyway, i was thinking of possibly modding it, so i wanted to ask ehre for some ideas. I was thinking maybe a key start or something to fix the issue of no starting button since it's ruined. Any other ideas on what to do to it ascetically?
https://linustechtips.com/topic/556985-nzxt-phantom-530-case-modding-ideas/
Welcome to the Forums!
Should I even ask how did rats get at it?
As for mods it depends what your wanting to do but some simple ones are getting vinyl decals or designs made for the case to add accents.
It was in storage, and i guess i must'n have had closed the box properly and they got in and made a nest in there!!
Well then... that's unexpected.
For sure you'd want to replace those cables and give everything a good cleaning. You may be able to get replacement accessories from NZXT directly but may need to contact them for that.
