Yes, you can overclock your GPU (graphics card) without overclocking your CPU.
GAMING PC "Ol' Bessie":
Ryzen 7 7800X3D | Radeon RX 9070 XT | Gigabyte B650M AORUS Elite AX | G.Skill Flare X5 6000MT/s CL36 16GBx2 | 5TB of SSD POWER | EVGA SuperNOVA 850W GT | Noctua NH-U14S | Fractal Design Pop! Mini AirCachyOS
Kind Of A Home Lab "Bay":
Ryzen 9 5900XT | Intel ARC A310 | ASUS PRIME B550-PLUS | T-FORCE 3200MT/s 16GBx2 + Corsair 3200MT/s 32GBx2 = 96GB!!! WOW!! | 2TB boot SSD + 8TBx6 HDD RaidZ2 | EVGA SuperNOVA 650W G2 | Phanteks Enthoo Pro M | Ubuntu 24.04 LTS
The Laptop:
Framework Laptop 13 | Intel i5-1340p | G.Skill Ripjaws 3200MT/s 16GBx2 | Solidigm P44 Pro 2TB | CachyOS
https://linustechtips.com/topic/556934-help/#findComment-7334180
2 minutes ago, Tridentmist said:
This won't have a affect on the performance of the computer. I am running a 980 ti with a intel 6500 i5?
Well, it should have the effect of increasing graphical performance. That's about it.
Core i5 6600k | Gigabyte GTX 970 Windforce | MSI Z170 Krait Gaming Crucial Ballistix Sport 16GB DDR4 2400 | NZXT S340 Red                                              EVGA SuperNOVA 750 G2 | Coolermaster Hyper 212 Evo | Razer Blackwidow Tournament | Logitech G600 Razer Kraken USB        If you want me to see your post, please remember to quote me!
https://linustechtips.com/topic/556934-help/#findComment-7334196
What do you mean exactly?
If you overclock your GPU, it will give you an FPS boost. If you overclock your CPU, it will give you an FPS boost. You can do both at the same time, or one at a time. If you want to, you may take off the overclock for either without taking off the overclock for the other. You'll be fine overclocking your 980ti with your i5 at stocks.
The Laptop:
https://linustechtips.com/topic/556934-help/#findComment-7334197
Thank you so much for your help!!!
saved my the worries
https://linustechtips.com/topic/556934-help/#findComment-7334204
You're welcome!
The Laptop:
https://linustechtips.com/topic/556934-help/#findComment-7334206
