Hi I have a AMD Phenom II 1035T processor and a Radeon HD 7970 GPU. I am upgrading the motherboard and the CPU to a FX 8350 and Sabertooth 990FX soon. With my current setup I only get about 3000 points per day max on folding@home and I was wondering whether anybody had any suggestions as what I should do to try and combat this. Thanks :)
XYPHER AMD FX8350 @ 4.6Ghz ASUS SABERTOOTH 990FX R2.0 AMD RADEON HD 7970 @ 1140Mhz 16GB Corsair VENGEANCE 1600Mhz OCZ VERTEX 3 240GB SSD Corsair H100i 1TB SEAGATE BARRACUDA FRACTAL DESIGN DEFINE R4 CORSAIR K90 MADCATZ RAT 3 iiyama ProLite B2480HS 24"
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/
Do you have both the GPU and SMP slots folding? If you switch to Expert view, you should be able to see the PPD of each. Also, for the AMD card, what driver version are you running? The newer ones have a bug that will limit them to 30% GPU utilization. Check with a util to see what load your GPU is at.
Forum Links - Community Standards, Privacy Policy, FAQ, Features Suggestions, Bug and Issues.
Folding/Boinc Info - Check out the Folding and Boinc Section, read the Folding Install thread and the Folding FAQ. Info on Boinc is here. Don't forget to join team 223518. Check out other users Folding Rigs for ideas. Don't forget to follow the @LTTCompute for updates and other random posts about the various teams.
Follow me on Twitter for updates @Whaler_99
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/#findComment-62875
ye with my overclock on my 7970 it runs at about 25% load at all times. And i am not sure but I think so for the gpu and smp
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/#findComment-62945
I am running catalyst 13.1 I think.
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/#findComment-62952
strange i get 11391 PPD on medium on my Phenom X6 T1100 am running CCC 12.6 though
Appelzaadje - the Insane
Intel i7-4770K - Maximus VI Formula - Corsair Dominator GT 1866mhz - R9 290X - Xonar DGX - Samsung 840 Pro 256Gb - 3X WD1001FALS - Raven RV01 - Iiyama B2409HDS 3x - Custom water loop - Windows 10 Pro - XFX tripple monitor stand - Steelseries 4HD - Logitech G9, G19, G35 and Z5500
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/#findComment-63202
Yep - it's those 13.1 drivers that are killing ya. You can either stop folding on the GPU and just do SMP or check out the FAQ which has info on this specific issue... It's stickied at the top of this sub forum...
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/#findComment-63252
i have to say from an crossfire point of vieuw i never take the latest drivers since they often screw up the stability of my system
https://linustechtips.com/topic/5568-why-do-i-get-such-low-ppd/#findComment-67065
