zipties and use modded cables if you have the money
CPU:Intel Core i5 6600K 3,5GHz  Motherboard: Z170 PRO GAMING  RAM: HyperX X Fury black DDR4 2x4GB
GPU: AMD Radeon HD 7800 series Case: some random shit tho it is gonna be upgraded Storage: SanDisk SSD Plus 240GB Cooling: Cooler Master Hyper 212 Evo Display: Asus VS278Q Keyboard: Roccat Arvo Mouse:Razer Naga 2015 Edition OS:Windows 10
https://linustechtips.com/topic/556749-need-help/#findComment-7332289
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/556749-need-help/#findComment-7332357
I say, format and re-install Windows. That seems to be the solution to everything.
Ok seriously,
I don't see a picture of your system. But basically what you want, is to take advantage of the whole of your case to pass wires. When you are new to it, it is NORMAL that it takes time. You may want to try different configurations. It can be annoying or fun, depending on how you see things, but this is how you build the skill and be able to better visualize things before doing things so that it takes less time. The main idea is to have short segments of wires that visible.
I also suggest to look closely at other peoples builds to get ideas.
https://linustechtips.com/topic/556749-need-help/#findComment-7333157
