Just checking: Will Corsair SP120 High Performance Pwm fans work with my H100i
Solved by Ex0Thermic,
having push/pull will not make that much off a difference. but will help a
little bit if you have bad air flow. (I only use push/pull because I can but in my corsair 350d case it makes no difference)
and yes the h100i can have 4 fans connected to it with no problems
Featured Topics
2
MiszS ·
Posted in New Builds and Planning16 -
2
Johnny Fehr ·
Posted in Windows4 -
5
13
5
18
5
