2 minutes ago, nipplesalad said:
So i just bought a new Sennheiser HD 451, but my cable won't reach my pc. i'm planning on buying an extension cable.
Could a cable make it sound worse?
it can yes but i doubt it will at that distance
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/555999-audio-jack/#findComment-7325127
1 minute ago, nipplesalad said:
Is 2M too much...?
i dont think that will affect it. it should be fine. i have a copper cable around my room which is like 10m and that is fine.
1
https://linustechtips.com/topic/555999-audio-jack/#findComment-7325146
its fine, just dont buy a POS from china, get something with good reviews and looks high quality
https://linustechtips.com/topic/555999-audio-jack/#findComment-7325155
