I'm using the AF120's and they don't seem to be as loud as my old fans.
These: http://www.amazon.com/Corsair-AF120-Quiet-Airflow-Single/dp/B00F6S10DC/ref=sr_1_10?ie=UTF8&qid=1456452656&sr=8-10&keywords=af120
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/555144-need-fans/#findComment-7316352
Do a giveaway! (Bad joke is bad)
But I have 3 AF120s and 1 AF140 (All quiet edition) in my system and they do super well and stay quiet
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/555144-need-fans/#findComment-7316362
2 minutes ago, TehStranger? said:
Hello,
I am looking for fans that are more effective at cooling and much quieter at full speed than the stock Corsair fans on my H105, any suggestions?
I don't care for aesthetics.
Cheers.
Notcua is the best, and you know what's better then Noctua fans? Noctua LTT edition fans!
http://www.performance-pcs.com/catalogsearch/result/?q=noctua+linus+tech+tips
https://linustechtips.com/topic/555144-need-fans/#findComment-7316363
7 minutes ago, TehStranger? said:
Hello,
Cheers.
Noctua NF12's
and holy shit that profile picture
https://linustechtips.com/topic/555144-need-fans/#findComment-7316388
3 minutes ago, TrigrH said:
maybe the fractal Venturi HP-12 PWM fans?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835352022
Deciding between those and the Corsair AF120's. The Corsair fans are listed as case fans, would it be less effective to use on my radiator?
https://linustechtips.com/topic/555144-need-fans/#findComment-7316616
yes they appear to be airflow fans you would want SP120 for rads
https://linustechtips.com/topic/555144-need-fans/#findComment-7316635
1 minute ago, TehStranger? said:
Would they be as quiet? What would you get between SP 120's and the fractal one
i think you are using SP120s?
https://linustechtips.com/topic/555144-need-fans/#findComment-7316652
6 minutes ago, TehStranger? said:
Alright so I guess I'll get the Fractal fans? Should be much quieter than these SP120's yeah?
going by the specs:
SP120L
Max RPM: 2700 RPM
CFM: 74.42
Fan Noise: 37.68 Dba
Venturi HP14:
78.1CFM at 1500RPM while reaching up to 30.1dB(A).
Venturi HP12:
61.4CFM at 1800RPM while reaching up to 31.7dB(A).
Going from this, the best option would be the Venturi HP14 using the optional mounting kit (included) so they fit on 120mm mounts (providing you have clearance)
https://linustechtips.com/topic/555144-need-fans/#findComment-7316688
4 minutes ago, TehStranger? said:
Actually somehow missed the SP120 part :P
I'm asking if the 5-7db difference will be noticeable.
7db less will be noticeable, if the fans are not quiet like advertised you should be able to return them no?
https://linustechtips.com/topic/555144-need-fans/#findComment-7316740
