My PC shut off earlier randomly and I was presuming this was just a software issue, but I checked the bios anyway. I found that my 4790K was hitting 99 Degrees. The fan on my cooler is picked up and runs fine, but the pump itself isn't picked up anywhere, and it used to say what RPM it was running at. Any ideas?!?
https://linustechtips.com/topic/555025-dead-h60-help/
Unless somethings not properly plugged in, it's probably dead. Sorry :/
https://linustechtips.com/topic/555025-dead-h60-help/#findComment-7315059
