1 minute ago, Carlos Garcia said:
Hey guys I'm trying to upgrade my CPU and ram for my cpu  I have a Intel Celeron 450 my mother board is acer x1900 and my ram 2GB kingston DDR3 dual channel
And? I'm confused what your question is.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/554899-help/#findComment-7313594
and what parts were you looking for ? and whats your budget and what are you gonna use the pc for ? you have the be specific lad :)
CPU:Intel Core i5 6600K 3,5GHz  Motherboard: Z170 PRO GAMING  RAM: HyperX X Fury black DDR4 2x4GB
GPU: AMD Radeon HD 7800 series Case: some random shit tho it is gonna be upgraded Storage: SanDisk SSD Plus 240GB Cooling: Cooler Master Hyper 212 Evo Display: Asus VS278Q Keyboard: Roccat Arvo Mouse:Razer Naga 2015 Edition OS:Windows 10
https://linustechtips.com/topic/554899-help/#findComment-7313595
You dont really have a huge upgrade path with a lga775 socket. Maybe look for a quad core xeon. You can get one for roughly $20
| Ryzen 9 3950X | EVGA 1200P2 | AMD 5700XT | ASUS Crosshair VIII Hero WiFi | G. Skill 4x16GB 3600Mhz CL16 F4-3600C16D-32GTZN | 2x1TB Samsung 980 Pro | Lian Li O11 Dynamic |
https://linustechtips.com/topic/554899-help/#findComment-7313628
tho he did want to upgrade his mobo aswell
https://linustechtips.com/topic/554899-help/#findComment-7313637
He didnt say anything about a new mobo
https://linustechtips.com/topic/554899-help/#findComment-7313664
ohh fuck i had a mind fuck i was reading that he was under mobo cpu and ram area idk i derped sorri
https://linustechtips.com/topic/554899-help/#findComment-7313672
https://linustechtips.com/topic/554899-help/#findComment-7313714
as long as you stay within the ram specifications of your motherboard
https://linustechtips.com/topic/554899-help/#findComment-7313721
X1900 has a motherboard using the G41 chipset so you should be clear to use most common LGA 775 quad cores. A modded Xeon should work but not all prebuild boards had the microcode for them.
A safe upgrade is a Q6600, Q8400 or Q9300 or any of their relatives. All are easily available on eBay or can be found used on Craigslist and the like. And as I said you can always shoot for a Xeon and give it a shot.
As for the RAM, literally any DDR3 should work with no issues, just probably no sticks bigger than 4GB. Some older boards do not work with high capacity modules.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/554899-help/#findComment-7314344
I want to do some video editing middle budget nothing to crazy want to get more features on my desktop running great graphics no lagg
https://linustechtips.com/topic/554899-help/#findComment-7321885
