nhowe? watercooling products
Guest
5 minutes ago, Slickwicked said:
ive been seeing these on amazon for a while, has anyone heard of this company before?
http://www.amazon.com/Nhowe-N-ig98-x-Colorful-Gtx780ti-Transparent/dp/B015DXIUA0
can find anything online for them, except they are a chinese company maybe lol
Sounds pretty shady to me. For that amount of money, just get EKWB.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
That would be the first time I've heard of theses guys, but for sure a company in asia, they are on Taobao:
http://world.taobao.com/item/41390131897.htm?fromSite=main&spm=a312a.7700824.w4004-9287433295.29.Du3b6w
As said it would be a good option to go with EKWB at that pricepoint and to ensure your getting a quality plating with that block.
do you have the one of the listed GPU cards?
Compatible model
  • IGAME GTX780-3GD5
  • IGAME GTX780TI
  • IGAME GTX780
  • IGAME GTX980
  • IGAME GTX980TI
if not, prolly will not be compatible.
what GPU do you have and location?
I was more just curious, I'm not buying one,
