980 TI Problem
8 minutes ago, RonShmuely said:Is there any way to re-install the windows I currently have without cracking/having the CD?
That would be quite difficult if you do not have a disk or bootable USB.
Luckely, i have an answer to it: This is the dutch version of the page where you can download W10, pretty sure there is an English version as well: https://www.microsoft.com/nl-nl/software-download/windows10
You can download windows 10, make an iso (and burn it on a dvd if you have a dvd drive), or make a boot-able USB, just follow the instructions and go from there. Be sure to back-up any stuff you want to keep on a separate USB, since the boot-able USB won't be working as a storage device anymore after you formatted and configured it for a boot-able device.
Windows 10 will be installed WITHOUT a license, so it may ask you to activate it and whatnot, and i am not familiar with upgrading to windows 10, maybe copy the CD key you have in use now, and use that key for the next install, since i can assume that one is a legit key, so it *should* work.
You can find your windows key in the properties of your computer (start >> computer >> right click >> properties>> scroll a bit down to see your key)
