I don't want to start a fight but I was just wondering what is the fastest card for light to modern gaming like counter strike , call of duty, I will be using a amd am3+ 8 core cpu and 12 GB of ram and a 600 W psu 80+ bronze. I do not care a lot about heat or power consumption.
https://linustechtips.com/topic/553873-best-card-for-200/
What psu specifically? And a used 290 or a 380.
https://linustechtips.com/topic/553873-best-card-for-200/#findComment-7302098
Have a look here.
Else used 290x.
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/553873-best-card-for-200/#findComment-7302109
