I am making the glorious switch from console to PC. I have been doing a lot of research on builds for the application I plan on using. I am looking for suggestions from seasoned PC gamers. The only piece of the build I believe I have figured out is the case. I plan to use the cooler master HAF 912 mid case I have heard many good things about it. To put into perspective the build I'm looking for something to run any 1080p resolution on high settings I play a lot of RPG's like the Mass Effect Trilogy and Elder Scrolls so I know it is going to need some power. My budget is about $1200 and I don't want to need to upgrade for a while. Thank you for your suggestions in advance. I prefer black and red color scheme but not a must my main concern is functionality I also need peripherals
https://linustechtips.com/topic/553863-my-first-pc-build/
17 minutes ago, Espen Vos said:
I am making the glorious switch from console to PC. I have been doing a lot of research on builds for the application I plan on using. I am looking for suggestions from seasoned PC gamers. The only piece of the build I believe I have figured out is the case. I plan to use the cooler master HAF 912 mid case I have heard many good things about it. To put into perspective the build I'm looking for something to run any 1080p resolution on high settings I play a lot of RPG's like the Mass Effect Trilogy and Elder Scrolls so I know it is going to need some power. My budget is about 1k and I don't want to need to upgrade for a while. Thank you for your suggestions in advance.
Any color scheme. Location? Peripherals? Do you need a monitor?
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7302060
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($249.99 @ B&H)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.75 @ OutletPC)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($79.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($67.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($69.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Cooler Master HAF 912 ATX Mid Tower Case  ($55.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA NEX 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ NCIX US)
Total: $998.56
Generated by PCPartPicker 2016-02-23 21:27 EST-0500
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7302062
Total: $998.56
You can do better on the psu.
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7302064
Also, are you set on that case? Because it doesn´t have a front 3.0 point.
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7302163
Here:
PCPartPicker part list: http://pcpartpicker.com/p/Mkn3qs
Price breakdown by merchant: http://pcpartpicker.com/p/Mkn3qs/by_merchant/
CPU Cooler: CRYORIG C7 40.5 CFM CPU Cooler  ($29.99 @ Newegg)
Memory: G.Skill Aegis 16GB (2 x 8GB) DDR4-2133 Memory  ($59.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($63.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($69.99 @ Amazon)
Total: $966.81
Generated by PCPartPicker 2016-02-23 21:46 EST-0500
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7302223
7 hours ago, N_Bot said:
The PSU you listed and the one I have are almost identical in specs. Minor differences in them. Nothing to fret over.
Please read this tier list. There´s more to psu´s than just their specs. Internal components play a big role in quality as well:
6 hours ago, Espen Vos said:
Thank you both for your recommendations I'm not dead set on the case if you have a better suggestion
Here: http://pcpartpicker.com/part/nzxt-case-cas340wb1
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7304188
will this current build work with that case?
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7306803
Yep, should work just fine.
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7307318
Can you please explain to me why the same company would list their MSRP for 2 different PSU's if they have different specs.
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7309178
10 minutes ago, N_Bot said:
Then they could raise the price of the better one to get even more profit? Anyway regardless, you were right.
But then that´d fall out of it´s value as well. Tier-lists also factor in the value and price of the product as well when putting them into a slot.
https://linustechtips.com/topic/553863-my-first-pc-build/#findComment-7309347
