So I posted a while back about this issue, was told to try and get a new cooler. So I have and have tried 3 different coolers in total. The problem is when I am playing a game the temps can go uncomfortably high to upwards of 75c+. So the question now is whether my next course of action would be to replace motherboard or cpu? Could the motherboard have incorrect sensors or the CPU simply runs a hot which would be more likely?
Thanks for any insight.
Specs:
  • i7 4790K
  • Asus Z97-A 3.1
  • GTX 970
  • 16GB Kingston
  • Corsair CX 750M
  • Phanteks Enthoo Luxe
https://linustechtips.com/topic/553637-high-cpu-temps/
use cpuz to get your temp readings. have you overclocked? have you used thermal paste?
  • CPU i7 4790k 4589.16MHz, Motherboard Asus Z97 Deluxe USB 3.1, RAM Corsair dominator platinum 16 gb 3977.3 MHz, GPU Nvidia 3080, Case Corsair 750d, Storage Samsung 850 pro 512gb, WD black 2tb, PSU Corsair HX1000i, Cooling Corsair H110i, Keyboard Corsair k95 RGB, Mouse Logitech G502 RGB, Monitor S2721DGFA, Sound Bose surround system, Operating system Windows 10
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299295
Stock clocks, I have CPU-Z and don't see temps I might be blind though. and Yes I used arctic silver and pre-applied thermal paste from the corsair one.
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299348
Do you know what your idle temps are? What's your ambient/room temperature?
 i7-5820k @ 4.4GHz | Corsair H100i GTX | EVGA TITAN X 12GB | EVGA All-In-One TITAN X Cooler | GSkill Ripjaws DDR4-2400 32GB
Asus X99-M WS Micro-ATX | Samsung 500GB SSD & Hitachi 3TB HHD | EVGA 750W Semi-Modular | Corsair 350D Micro-ATX Case
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299351
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299368
Hold up, we are ignoring a simple yet possible issue...can your case breathe?
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299387
I have had it in two different spots in what I would consider pretty average spots for a computer to be. Its right next to my desk on hard wood floors.
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299415
1 minute ago, Asyylum said:
I would say its in average spot I have had it in 2 different spots and similar results. Its next to my desk on hard wood floors.
Open space is good, but some cases lack ventilation and some people overlook that, you could use an industrial fan but it wont help if you case is under ventilated.
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299446
I totally understand that, my case is a Phanteks Enthoo Luxe so it should have enough airflow assuming it gets enough air from the exterior reasonably well. Which I feel shouldn't be much of a problem. Good suggestion though I totally forgot to consider that.
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299461
Try doing a live boot from a linux system usb(not install or format, just live disk) or a virus scan, some firmware and malware attacks will mess with you config files and cause over heating or prevent cooling.
                   _/ V\
    ______|   __/_/| |
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299483
What distro do you reccomend?
https://linustechtips.com/topic/553637-high-cpu-temps/#findComment-7299497
