Hi I want to ask you guys is everything correct and matching up
CPU: AMD Athlon II X4 860K
Motherboard: Asrock FM2A58M-VG3+R2.0
RAM: Crucial Ballistix 8GB DDR3 2x4
PSU: LEPA MX-F1 500W
GPU: MSI GF GTX750 TI 2GB GDDR5
HDD: Seagate BARRACUDA 7200 1TB
CASE: Zalman Mini Tower T3
https://linustechtips.com/topic/553630-help-me-with-budget-pc/
Use Pcpartpicker. And don´t get that psu.
https://linustechtips.com/topic/553630-help-me-with-budget-pc/#findComment-7299201
There are much better cards than the 750Ti.
Look at the GTX 950 and...270? or equivalent from AMD.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/553630-help-me-with-budget-pc/#findComment-7299203
2 minutes ago, DeivisBiceps said:
Whats wrong with it?
I'd recommend you google the parts you are investing on or go with a safe brand that you can rely on: Corsair, EVGA, Cooler Master, Silverstone, just to name a few. Make sure you get 80+ efficiency and I'd even recommend on getting 80+ gold or above to get a long lasting PSU that will last several builds.
https://linustechtips.com/topic/553630-help-me-with-budget-pc/#findComment-7299274
28 minutes ago, Starelementpoke said:
Just a bad quality psu.
*Cough*Used 7950*Cough*
I think there are better options than that out there ;)
I'd aim for a 280x, maybe even a 290 though there's always the risk of mining cards.
https://linustechtips.com/topic/553630-help-me-with-budget-pc/#findComment-7299445
Those cost like $150 and $225 used respectively though. You be finding 7950's which are pretty much the same as 280s for $100.
https://linustechtips.com/topic/553630-help-me-with-budget-pc/#findComment-7300364
I've seen them a lot lower, I've seen 780's for the latter price on a pretty consistent basis ;)
FWIW I picked up my 7970 for $50.
https://linustechtips.com/topic/553630-help-me-with-budget-pc/#findComment-7300399
