I like ear buds but all of mine done how start to break near the audio jack for some reason I have been looking for rear bus that are know to last long and sound great. Does any of that sound or seem, in anyway, familiar? I currently have munitio mw3 edition earbuds. I have been using munitio for years but only like these earbuds because of their quality construction. I just want to know if there are any others that are just as good or better.
https://linustechtips.com/topic/553402-durable-quality-earbuds/
20 minutes ago, iShad said:
You should check out noble audio stuff as well, and I'd look into getting linum cable as well as all the stock one is really bulky with an annoying hook.
You don't like the stock 64audio's cable? I'm running my 4R with it and i think it's fantastic. No cable noise and it's really durable as well
https://linustechtips.com/topic/553402-durable-quality-earbuds/#findComment-7298020
Yeah, the hook was especially uncomfortable for me but you're right that it is quite durable.
https://linustechtips.com/topic/553402-durable-quality-earbuds/#findComment-7298042
