I'm having problems with my internet. My computer (connected to the modem with ethernet cable) gets really slow speeds most of the times. This occurred shortly after we got a new modem. I don't think that's the problem since other computers works fine with it. Sometimes the speeds are normal and I get normal speeds on speedtest. I have tried to solve this problem but I cant find a solution. I have avast and I have also ran malwarebytes anti malware with no results. Also when I connect my laptop with the same cable the speeds are normal, so the cable should be fine. I have also tried different browsers, different dns servers but nothing seems to work. I don't have any torrents running or anything. I have also tried to reinstall network adapter drivers. I have also tried turning off firewall. Any help would be appreciated.
This is the slow speed I usually get, normally it should be like 22/1:
This is the speed i get with my phone connected to the wifi:
This is the speed I get when I connect my phone to my computer with usb and share the internet:
https://linustechtips.com/topic/55328-slow-internet-speed/
Are you sure WiFi is disconnected from that PC (if it has WiFi build-in)?
https://linustechtips.com/topic/55328-slow-internet-speed/#findComment-743736
I don't have WiFi in my PC/Mobo
Have you tried using a different cable?
https://linustechtips.com/topic/55328-slow-internet-speed/#findComment-743747
Try using a PCI-e NIC and see if that helps anything.
https://linustechtips.com/topic/55328-slow-internet-speed/#findComment-743767
what's that lol
It's an ethernet adapter PCI-e Board. It's what you would have to use if your motherboard didn't have a Network Interface Card built in.
Come fold while not gaming! http://linustechtips.com/main/forum/37-foldinghome-boinc-and-coin-mining/
Gaming Rig: i7-9700k 5GHz all core, GTX 1070, 16GB TridentZ, Buncha ssds...
Stream Machine: R7 1700, GTX 660 (lol), 16GB Corsair Somethingoranother, 120 GB SSD i've had since 2012.
Mobile Workstation: MSI-ALPHA :R7 3750H, RX 5500M, 16GB of some ram, 500GB SSD.
https://linustechtips.com/topic/55328-slow-internet-speed/#findComment-743823
