2 minutes ago, DeckyFPU said:
Well I spilled juice on my pc a couple of weeks ago by accident and now I think my mother board is broken. I'm needing he'll understanding why my motherboard powers for around 10 seconds then restarts itself
Probably killed some RAM, or PSU, Specs?
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
https://linustechtips.com/topic/553052-help/#findComment-7293395
Usually water damage on boards is quite visually detectable. It sounds like you already know the cause for your issue, so short of a professional repair where someone re-solders the damaged component, it sounds like a new MB is in order. A pic would be helpful to determine how extensive the damage is, and whether or not other components may have been impacted. Taking it to a professional repair facility may be your best option in this case, unless it was old enough just to warrant buying something new.  Your data will likely be able to be recovered and transferred to your new computer.
|[ i7 6700k ][ MSI z170a XPower Gaming Titanium MB ][ 16gig G.Skill Trident Z 3000mhz ][ Gigabyte Xtreme GTX 980ti ][ Samsung Evo & Intel SSDs ][ Corsair 540 air ][ XFX Pro 750w Platinum ][ 24" Asus 144hz ]|
https://linustechtips.com/topic/553052-help/#findComment-7293483
specs-
12 gb ram, 2x4gb hyperx beast 1600mhz and 1x4gb hyperx fury 1600mhz
gigabyte z87x-sli
600w fractal design essence
intel core i3-4160
i know what caused the problem, im just confused as to how the motherboard still powers if its damaged.
the juice was irn bru
https://linustechtips.com/topic/553052-help/#findComment-7293687
