PSU is overkill and motherboard is also kinda overkill. Other than that it's fine.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
3 minutes ago, Darkzed1 said:
Hey guys I have revised my build a ton and would like some advice from some more experienced builders. (This is my first build) I am thinking about switching the motherboard to an Asus one any suggestions?
http://pcpartpicker.com/p/zwwWWZ
Nope thats all awesome, only thing I would do is buy a better cooler, this is what I surgest to take advantage of the CPU. Its a great system non the less! http://pcpartpicker.com/p/FPRDD3
CPU: Intel i7-4790k | Cooler: Corsair H110i GT | Motherboard: MSI Z97I AC  | Graphics Card: SAPPHIRE R9 280  | http://uk.pcpartpicker.com/p/pszsdC
http://adamredfern.co.uk
http://rewinded.co.uk
http://yewtreeservices.co.uk/
http://asiat.co.uk/
http://ssstelecom.co.uk
http://hndrx.co.uk/
http://wisemove4u.com/
SLI is a waste of money. But over all awesome build!
Yo, if you are just using the 850 EVO as a boot drive... Maybe consider the Samsung SM951 M.2 Drive instead.  Check it out... eh?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
Planning on running 4K games on ultra settings
That doesnt mean you need an overkill psu or motherboard.
not for 4k
Gaming HTPC:
Desktop PC:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
9 minutes ago, Darkzed1 said:
Any suggestions for a motherboard?
You might consider this board.
Motherboard: Gigabyte GA-X99-SLI ATX LGA2011-3 Motherboard  ($189.98 @ OutletPC)
http://www.tweaktown.com/reviews/7251/gigabyte-x99-sli-intel-motherboard-review/index11.html
