I'm planning to get an NZXT S340, and my airflow plan is negative I'm planning to put a dual radiator in the front exhaust push fan, and 1 Corsair SP 140 in the rear and 1 in the top exhaust type. in this case is my airflow good? even though I dont have any AF intake fan? or should I use a single radiator and put it on the rear or top, and 2 AF fan intake in the front?
https://linustechtips.com/topic/551477-case-airflow/
are your front 2 fans intaking and the other 2 as exhaust?
if so, it'll be fine,
I run my S340 with one intake and one exhaust fan and it works fine.
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/551477-case-airflow/#findComment-7277104
1 hour ago, LukaH said:
any fan that will push air across the VRMs and effectively deliver fresh air into the case will do fine. They may not move as much air as airflow optimized fans but something is better than nothing ;)
what about a single radiator with an exhaust type and I put this on rear or on top and 2 AF intake fan on the front this is better right?
https://linustechtips.com/topic/551477-case-airflow/#findComment-7278845
That would be better yes :) but with the configuration you initially posted i would just flip the dual radiator fans around and have them as intakes. The air that will pass through the warm radiator will only be a degree or two hotter so if you are worried about delivering "hot air" into the case.
GPU drivers giving you a hard time? Try this! (DDU)
https://linustechtips.com/topic/551477-case-airflow/#findComment-7278889
Thanks
https://linustechtips.com/topic/551477-case-airflow/#findComment-7278903
