Monitor for gtx 960...20 inch or 22 inch?
Soumyangel
i have a gtx 960 coupled with i7 4790...playing games on 1600x900 but i wanna upgrade ....should i keep the 20 inch samsung or get a 1920x1080 panel?? would games lag? i am confused...name me some brands....am from india
i7 4790,zotac nvidia gtx 960,16 gb ddr 3 corsair vengeance,cm b600 v2,gigabyte h97md3h,2tb seagate+2tb wd,samsung 20",asus xonar dg + 5.1 creative,sennheiser hd202,cooler master elite 311,apc rs 1000g,logitech c270,xbox 360 controller for windows and d link wifi router..
not really
I used to have a 960 that demolished 1920X1080
only when I upgraded to ultra wide was the 960 no good
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
You should upgrade to a 1920x1080 panel. The 960 will definitely be able to handle every game thrown at it :)
              PC Specs:
CPU: i7-5930K | Cooler: Corsair H100i GTX | GPU: GeForce GTX 980 Ti | Mobo: ASRock X99 Extreme4 | Memory: HyperX Fury Black 16GB | Storage: SeaGate 2TB & SanDisk 120GB SSD | Case: Fractal Design Define R4 w/ Window | PSU: EVGA SuperNova 750W Gold Cert | Monitors: (x2) Acer S220HQL | Keyboard: Razer Blackwidow Chroma | Mouse: Corsair M65 RGB |
960 can perfectly handle 1080p
LG, ASUS, ACER, DELL
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
guys really? actually am playing games at high on my 20 inch samsung at 1600x900 and i dont want to loose that fluid gameplay over a hd screen...but i guess u guys are right am undermining the capability of my gfx card..so any good monitors in sight? i wanna go for asus...but shld i go for samsung?
